atraudes »
https://forums.nicoclub.com/atraudes-u214401.html
Fri Feb 05, 2016 9:59 am
Well, it could be a number of things, so here's some quick and easy things you can try to narrow it down a bit. Next time, before trying to crank it, turn the key to the On position, keep it there for 2 seconds, then turn it off. Repeat this 4 or 5 times, then try starting without pressing the gas pedal.
Also try a fuel system cleaner (Seafoam?) or fill up with something like Chevron and drive it for an hour or so.
If neither of those bear fruit, pull the intake boot off and check your throttle body. If the inside is black or has excessive carbon buildup, try cleaning it. Also, listen under the hood while the engine is running and see if you can hear any vacuum leaks.
Are there any circumstances where it starts up with no complaints (when it's warm, cold, only been off for a minute, etc.)?
Try those things and let us know what you find!
