RyanL83 »
https://forums.nicoclub.com/ryanl83-u248031.html
Mon Feb 16, 2015 10:07 am
First time poster here, so please go easy on me if I mess up some forum etiquette. I've owned my 04 Pathfinder for about 3 years now, and it's been a great experience. However, I've had a problem over the past week or so, where the SLIP and VDC OFF lights on the dash come on and won't reset until I turn the truck off/on. The service engine light also seems to be coming on sporadically. I have not reset it yet as per the owner's manual, so I am not as concerned about that one. The issue with the other lights though, I can't figure out. A bit of digging seems to show that it could be an issue with the brakes, but after topping up the fluid and confirming that all 4 brakes are in good shape, they are still coming on. I do have a code reader (Bluetooth OBDII with Torque for Android), but I don't get any fault codes, other than one that I know was already there before this started happening. I am not that experienced with Torque, so maybe there is something I need to tweak in the app to get the full list of codes?
One clue that might help is that I accidentally killed my battery about a week ago while troubleshooting another issue. That problem was the dash lights (and tail lights I learned later on) kept blowing fuses. I nailed it down to an issue with my trailer wiring harness, which I ripped out. I am fairly confident, though not 100% certain that the SLIP/VDC OFF lights came on for the first time not long after I brought the battery back to life. So I'm not sure if the battery dying could have buggered something else up, or if the short from my trailer wiring maybe caused a problem somewhere else. My 4WD light was also on after the battery died, but I was able to fix that with some kind of reset sequence from the service manual.
Performance wise, everything seems perfect. No issues with the brakes, no loss of power, no stalling, all of which were reported by other people with similar vehicles and the same issue. I've skimmed the owner's manual for clues, but didn't turn up anything.
Sorry for the wall of text, but I was trying to provide as much detail as I could. If anyone has any info that could help, I would very much appreciate it!!
