Bubba1 »
https://forums.nicoclub.com/bubba1-u2509.html
Mon Sep 28, 2020 2:00 pm
Pathys have always had a good reliability reputation. But keep in mind it's a 16 yr old Pathy, so it's getting to the point where original, more expensive components are becoming possible issues. Checking the thermostat was a wise first try. You mentioned "cold heat" plus it running hot. To me, that sounds like a possible clogged/bad heater core, which can cause overheating as coolant circulation is reduced, plus no heat, of course. Hopefully it's something far less expensive than that, like low coolant, or an inoperative fan, or tired water pump, but the heater core would be my guess.
Good luck.
