EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.html
Fri Jan 27, 2017 7:30 pm
Sure hope so too, but it doesn't seem likely that the issue is the remote since even when I replace the battery nothing funky happens to my key fob.
OP, if you haven't tried, can you verify that these actions still unlock all the doors:
1. The master lock buttonon the driver door armrest will lock and unlock all doors when the door is shut/ or open with the engine off
2. If you push the master lock while the engine is running, the doors lock then unlock immediately.
3. If you put the key in the driver door lock cylinder and unlock it twice, it unlocks all the other doors on the 2nd try.
4. If you put the key in the hatch lock cylinder and unlock it twice (counterclockwise), it unlocks all the doors.
Not sure where your dent was, but I know some paintless dent removal procedures involve drilling into body panels.
