ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sun Jul 10, 2011 11:46 am
Think about the answer, did you see any small black flecks of rubber O ring in the drained ATF fluid? Were there any particulates in the drained oil?
If that is a possibility there may be or still be contamination within the solenoid pack that drives the gearing especially an up gear then a counter drop down to a lower gear.
Your described symptoms lead me to this and I have experienced it with my own Nissan product 97 QX4 and I discovered a quick oil change of about 4-5 liters of ATF has cured my vehicle of this symptom. The oil change is via the drain port in the drain pan, leave the pan on and alone. When you removed the pan what shape was the seal in around the edge?
Contamination by small particles of metal, fiber will slow down hydraulic operation of valves and you may get lucky and clear these valves that are preselected by electric solenoids.
While doing the oil change examine the drained oil for looks (pink and bright, burned, smells and dull not pink, and feel. Run your fingers through the oil feel for grit and rub your thumb and index finger together feeling for grit. Lastly as you pour the used oil into a container for recycling look carefully for big fiber bits, rubber as in O rings and metal filings.
All these things may be in this oil since the transmission works by mechanical, hydraulic pressure acting on fiber rings, cut metal gears and all these things wear but it is up to us to get the crap out.
An annual oil dump is cheap, helps clean up the garbage but the best thing it allows us to look inside a transmission without going inside a transmission. Some call it insurance, I call it PM.
