pm.nuculovic »
https://forums.nicoclub.com/pm-nuculovic-u211960.html
Fri Nov 09, 2012 11:07 pm
Hello,
I just replaced a motor in a 04 maxima and I received the car already half apart with the harness all over the place I got everything running besides brake light and abs light and then transmission went into safe mode (say its in 5th gear) found a connector that I couldnt find the other half of it, its near the driverside strut tower and their is a total of 3 connector connected to a mounting plate two gray harness connectors that are connected and 1 black one that I cant find the other section of it not sure if it is even used but it does look clean and under that all the way in the bottom of plate there is a abs sensor connector. If someone could help me with this that would be awesome!! pic would be great if someone could provide some!!
Thanks,
Mike
