Brodie »
https://forums.nicoclub.com/brodie-u17924.html
Fri Jul 09, 2004 9:58 am
New (4 weeks) 04 Murano SE, 5000 miles, enroute from Calif to Okla (return) started having problems: Barstow, 1p: overheating while idling briefly; Kingman, 4p: overheating while idling briefly (normal temp once at speed); Seligman, 5p: A/C stopped blowing cold air; Williams, 6p: speed fluctuating, RPMs fluctuation - more than normal even with the CVT - dropped out of cruise but was not on a significant climb; Flagstaff, next am, sitting at the dealer waiting for the service dept to open: lights on without switch on; also - alarm horn chirp inop (actually, didn't for multiple times; then chirped once; then didn't).
Dealer in Flag ("Planet Nissan") spent most of the day determining that a service bulletin indicating ECM (engine control module - the main control computer apparently) was going into fail-safe mode, indicating major failure.
Service found that a national backorder exists on the ECM - estimated availability 24 July (this was on Tuesday, 6 July).
Dealer attempted to get Customer Relations involved, which I did, too. Because I had not purchased any of the extended warrantee packages, no coverage for rental car, overnight, getting my car back, etc. is normally provided. I am waiting to hear if they will make an exception.
I just wanted to post to see if this problem was known by anyone else; if the ECM national backorder indicated such an unusual occurance that no parts were available or if it indicated some kind of run on these parts with multiple failures; and to post the symptoms which to me seemed weirdly unrelated.
Cheers all.
