Post by cars15 » https://forums.nicoclub.com/cars15-u225727.html Fri Sep 27, 2013 3:25 pm
Post by OwnerCS » https://forums.nicoclub.com/ownercs-u161666.html Sat Sep 28, 2013 5:18 am
Recheck the vacuum hoses and sealed connections. A loose vacuum hose or PVC valve that allows a leak in manifold vacuum can sometimes cause difficulty running at idle. Also check other electrical connections removed during the timing chain operation that may be loose.cars15 wrote:I have a 2004 maxima in which I just change the timing chain couple days ago... everything went great until this morning the car wont stay on unless I push the gas... once the gas is push the car remains on... I already change the battery.. what can be the cause??
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
