MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sun Oct 26, 2008 7:18 am
I would only suspect the alternator if the battery AND brake lights were coming on. Generally in that case, they also fade on and off intermittently, usually correlating with RPM.
Have you re-checked the brake fluid after filling? Is it still at full? It can look full with the car off and brakes off, but once you start using the system, fluid will begin working into the system and the reservoir level can drop if fluid was particularly low when fluid was added.
