jsmithsole »
https://forums.nicoclub.com/jsmithsole-u52504.html
Mon Apr 16, 2007 2:31 pm
It's a tight fit but you can get to them, the dealer would recommend removing the bumper (which is easy as well but unecessary)For the driver's side you need to remove the intake or the stock air filter. This will give you access to the bulb. For the passenger's side, remove the fluid reservoir (there's 2 10mm bolts holding it in place). After that you'll need to remove the fill tube for the windshield washer fluid. You can do this by twisting it counter clockwise. After that you should have access to the bulb.That's it!
