Dang... I was REALLY hoping that the 8500K rating on the fogs you ordered would do the trick... This is most annoying. Now i realize that we have been over this before, but do you think those crazy-long overpriced H3 LED fogs in the beginning of this thread will fit in the fog housing, Boon? They are way longer than a typical H3 bulb and I am worried about their fitting inside the housing. If you think they'll fit, I'll order them and install them, even though the light output will be very minimal. I just really want the color temperatures to match.
The very newest 5Watt LED's aren't yet available in an H3 format. plus I have a feeling you may run into that same resistor-load problem and they won't light (perhaps).
I gotta give something a try...
take a look at:
http://www.v-leds.com/Shop/Con...46237
let me know if they'll fit.
By the way, Boon. take a look at the load-resistors sold by V-LED's. they may be what is needed to make the 1W LED's you bought earlier to work in our fog application..
http://www.v-leds.com/Shop/Con...num/3
Thanks,Nite
Modified by xxNite at 4:34 AM 4/2/2008
