04 LE does this have limited slip differentials?
dan96max
Car: 96 red max SE 5spd/04 Pathfinder LE Platinum
Just trying to buy some gear oil so I can change the fluid in the front and rear end. How can I tell if its limited slip in the front and rear. It's telling me I need LSD GL-5 80w-90 if I do have LSD. Should I assume that because its an LE their LSD?
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
there should be a big-a$$ orange sticker on your axles if you have lsd
Modified by miamiheat3332 at 3:13 PM 9/3/2009
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
It's easy to check. Jack the truck so both wheels are off the ground. Puttranny in neutral. Turn one rear wheel by hand. If the other rear wheelturns the same direction, you have LSD, if the other direction, no LSD.
Fisherdude
Car: 1996 Nissan Pathfinder 4x4 SE
If my 96' pathy has LSD then yours does too.
