So I have spent a lot of time reading all the posts on this, but I am stuck...
Repair: Idle Air Control Valve replaced due to failure to idle (then car sat for 6-8 months on a maintainer.... which may have failed, jumped and ran)
Currently: runs and drive, power level seems low, engine idles at 1600-2000rpm and surges from 1500-2200rpm, when in gear the RPMs go down but if you let off the brake the car wants to go quickly.
What I've done:
-Found large vacuum leak, fixed
-Tested TPS - checked out (.55v at idle, <4v at WOT engine off)
-Tested MAF - checked out (1-2v at idle, 3-4v at 1/4 throttle engine on)
-Inspected for additional vacuum leak - none
-Clean airbox, air lines and anything prior to Throttle body
-Wiped clean throttle body
-Unhooked battery for 12+ hours
-"Attempted" to complete the relearn process (
how-to-ecu-relearning-procedures-t445702.html) but cannot get the "service engine soon" (CEL) to flash, I suspected that maybe the battery voltage was too low so I attached a charger during the process. Went through the process and this time it did start flashing... but didn't stop, just alternated between a slow flash for approx 10 seconds then a quick flash for approx 10 seconds. I turned the car on and the CEL appeared to echo the surging on the engine in no real pattern (sounds weird I know...). Re-stared and the CEL is off... no codes stored with OBDII scanner.
I am lost and not sure what else to check... I am going to try another 12+ hours unhooked battery then try the relearn again. I found it odd that fixing the vacuum leak did not correct the surging issue.
Would appreciate any help. Been researching on here and trying my hand at it for two days now.
