04 Infiniti G35 CD player problem
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Josr
Car: 04 Infiniti G35 coupe
Is it common for the CD player to only work on one channel?
I have only had the car a few days and tried a CD but, only the right side speakers worked.
The radio works fine.
I read something somewhere that they had ribbon cable problems.
Looking for insight
Reason: Revise Title
telcoman
Josr wrote:
Sat Mar 06, 2021 8:19 pm
I have only had the car a few days and tried a cd but, only the right side speakers worked.
Looking for insight
No, it is not common and indicates a problem with a seventeen year old CD player.
Your post was not clear, but if the FM radio works in both channels then you have a defective CD player.
If you only get sound out of one channel with all audio functions then you most likely have a harness wiring problem.
Good luck
Josr
Thanks
I haven’t tried a different CD yet.
Been busy changing struts and fluids.
Think I’ll go try right now.
Josr
Well I didn’t realize the in dash CD player held more than one disk.
I pushed the eject button and a disk came (not mine).
I pushed again an another disk came out (not mine).
Put mine in and plays fine.
Guess I should have read the directions.
wrightdog26
Car: 2004 Infiniti G35 sedan
My 98 Camry had the same issue. I contacted Crutchfield.com since they have lifetime tech support. I bought the head unit from them and installed it myself. They suggested it was the unit. Cd plays only on one side. Radio and auxiliary input was ideal. Installed a new unit and no issues since.
Return to “G35 and G37 Interior, Exterior and Audio”
