hooty80 »
https://forums.nicoclub.com/hooty80-u174287.html
Mon Dec 13, 2010 7:25 pm
VDC Off, Engine Service & Slip light were all on. Car had trouble starting. Took to local Nissan dealer and determined the CRANK & CAM Sensors needed to be replaced. ($731USD). Sounds expensive right? Paying the price, need my car.
Found the article below regarding an earlier recall (I never received any information on BTW). Wondering if this would still apply to my situation?
2003 Infiniti G35 Recall ID from NHTSA: 03V455000Auto Recall Date: 11/17/2003 Vehicle Component: ENGINE AND ENGINE COOLING Estimated Vehicles Affected: 630000 2003 INFINITI G35 Defect Summary: ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS. Defect Consequence:THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH. Remedy: DEALERS WILL REPLACE THE CRANK POSITION SENSORS. CAMSHAFT POSITION SENSOR(S), AND IN SOME CASES, THE VARIABLE TIMING CONTROL SENSOR(S). VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 1-800-647-7261 OR INFINITI AT 1-800-662-6200 1-800-662-6200 . Notes: NISSAN NORTH AMERICA, INC., R3021/R3022
