tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Tue Jan 22, 2008 12:34 pm
if its not visible, i'd recommend pulling off the back seat. Its easy, and you can see if there is anything wrong with the lever.
use a flat screwdriver to pry the white tabs off the clips in front of the seat on either side, then you should be able to just lift up and off
