Poyzinous wrote:I saw that once in a friends maxima. He did his own 'repair'. Those fans were blowing so hard the car would go backwards in neutral but then they burned up after resistance from incoming highway speed winds
On heavy industrial equipment the fans are usually reversible on any equipment that doesn't have a cab. Either you turn the individual blades on engine driven fans or reverse the plugs. This keeps dust from coming back on the operator and during cold weather you can blow warm (actually more than warm, I used to operate a D8 cat) if flowing front to back. I have been on the machines before where someone has started to reverse the blades and never finish so you have half the fan blowing one way and the other half blowing the other. Machine then is the one getting hot.
Most of the time when I have seen this on cars for some reason it has been where only one of multiple fans blew the wrong way. This is why I mentioned short circuiting. This will often go unnoticed during moderate weather but shows up during hot weather when air flow is simply short circuiting between the fans. One fan pulls in cool air and it gains heat from the radiator and then is sucked in by the other fans and picks up more heat yet.
Perry
