04 G35 coupe with H&R springs, camber questions
barrettbenson
I just bought an 04 G35 coupe with H&R springs. The negative camber is prolly like 3 degrees. With these springs, and having a shop try to fix this, can i get it back to a reasonable level of camber, or should I get some A arms to fix the problem?
IlsG35
Car: 2003 graphite 6speed G35
stock arms dont allow for that uch adjust ment anyways. i have stock suspension on mine and only got my camber to go negative a little bit. if u want ur car to handel better go negative camber if u just wanna do drag racing set ur camber to a dead even zero and i forgot wat positive camber is for.
