SVTCOBRA wrote:Haven't taken these seats out before. Pretty ez?? Guess I'll look in the FSM.
But, would a loose wire or connection make the seat move???? Without the switch engaging?
Will try jarring the switch on the way home to see if that does anything.
Maybe its jarring the switch or a wire and thinking that the switch is being depressed. Or maybe the switch itself is jarring.
For the seats.
4 bolts.
After popping off the plastic covers.
Unbolt front, move seat forward, unbolt the back, then I move the seat to about the middle.
Then unhook the battery, let it sit for 15 mins or so.
Pick up seat and lean it back to unhook the 3 connectors on the bottom
Pull it out of the car.
When putting back in, just make sure to hook the connectors back up before reattaching the battery.
