04 Frontier Wiper Arm
jl_04nf
Car: 2004 Nissan Frontier
The passenger side wiper arm is not pushing up. I figure once I get the dash apart to find the problem it will be an easy fix. I'm curious if any can explain how to take the dash apart to get to it and how difficult this process actually is. I'm a college student with limited resources and time. Just curious how difficult and time consuming this process could be.
Thanks
nissangirl74
Here's a link to the entire Factory Service Manual for the '04. You should find what you need here.
http://www.nicoclub.com/FSM/frontier/2004/
Here's the link to the directions for swapping our the wiper. Scroll down the page, almost to the end.
http://www.nicoclub.com/FSM/frontier/2004/ww.pdf
Hope this helps. Welcome to NICO. :wavey:
keepinsane
Car: 2002 nissan frontier
There is a cap on the wiper arm itself! it just pops up, and there is a nut you must make sure you tighten it. Had this problem a month ago thought it was serious took 2 min to fix
Q451990
I'm pretty sure taking the dash out won't do anything for you. The linkage and motor are all accessed from under the hood and cowl cover.
Heath
PEZi
Q451990 wrote:I'm pretty sure taking the dash out won't do anything for you. The linkage and motor are all accessed from under the hood and cowl cover.
Heath
this
Theo
Car: 2006 M35X - sold (now 18 Accord Touring)
2012 Xterra SV 4x4
keepinsane wrote:There is a cap on the wiper arm itself! it just pops up, and there is a nut you must make sure you tighten it. Had this problem a month ago thought it was serious took 2 min to fix
what he said. I just had to do the same thing
