Which do you recommend and why? Thanks!
I went with Michelin Pilot AS3 and they felt much better than OEMjoe603 wrote:Replace all with Conti DWS. I put them on my G37 and they felt much better than OEM.
It's always tricky to have two different tire construction and tread compounds on the front and rear. It WILL affect your handling and not necessarily in a good way.SVTCOBRA wrote:I should have said...I currently have DWS at all 4 corners. About 33K miles on them with no rotations.
Rears lost the S....The fronts still have DWS.
Wonder if the Michelins would do better.
The DWS were def. not as sticky as the S-Drives and not nearly as much fun in the corners due to the DWS soft side walls.
now leaning toward just getting 2 rear DWS....or maybe 2 A/S 3 on rear, then A/S 3 on front later.
