jonvia1234 »
https://forums.nicoclub.com/jonvia1234-u316301.html
Fri Mar 28, 2025 5:29 am
This is going to be a long post, so I apologize in advance. Have a 2004 Nissan 350z drift car, long story short, car needed parts fixed (angle kit, new front fender etc) Car has been sitting on the trailer waiting on parts. Parts finally come in, a few weeks later. Same day we go to start the car because it hasn't been started in forever. Starts no problem. Get to replacing the pass front fender, finish up the angle kit parts and bam no crank no start. Security light full red. Car hasn't even moved off the trailer mind you. Try to hook up a scan tool and no communication at all. (tested scan tool on other vehicles, works fine)
okay, so things we have done/tested: new starter, tested for power at starter wire (12 volts), replaced IPDM box, check every single fuse in every fuse box, replaced BCM and footwell fuse box to see if it would at least let a scan tool communicate, removed engine grounds and sanded/wire brushed them, did the "escape lock mode" key thing, battery is good, tried jumping battery just in case, swapped relays (ecu relay and etc), checked for loose connections under car, sent ECU off to be tested, came back as good and communicating said no codes were present, replaced NATS antenna, jumped clutch switch wire nothing, tested resistance on pins 7 and 14 on the obd connector, no short circuit, passed test. Took it to Nissan dealer couldn't get their tool to read either.
My ultimate question is, if the security light is on, will it disable CAN communication completely? Been looking over wiring diagrams/forums and cant get a direct answer. Our next step is to send the ecu off to have NATS deleted. Any input would greatly be appreciated, we are going insane trying to figure it out. Please send help lmao
