samej82 »
https://forums.nicoclub.com/samej82-u66984.html
Sat Nov 17, 2007 7:54 pm
I'm guessing your looking to get a used 350z and looking for 350z related problems to inspect?Clutch feel, clutch travel, Transmission syncros or any unusual grinding during shifting and if it's slipping.. How's the interior plastics?, Any wierd smells in the cabin (could indicate mold from water damage), Window door seals and if the power windows are operating properly (has been some issues), any unsual idling sounds from the vq like metallic tapping or uneven idle, check the battery voltage on the gauge as well as oil pressure. it should be in their normal ranges at idle and under higher rpms.
Belts & hoses, body paint, body panel alignments (unless ur sure it hasn't been in an accident)
Drive it see how it feels (tire with flat spots) and listen for any rattling (interior components & improperly hung exhaust etc.).
Good luck.
