04 12k miles noise at idle
Nissan 350z / Nissan 370z general community discussion forum
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
get a clanging noise at idle its louder then the exhaust when i first start up the car release the clutch about 10-20 seconds later i head a clang from what sounds like the transmission about every 15-30 seconds and it dosent go away you guys have any idea ? its still under warranty untill december if nissan replaces transmission do they put a new one in ?
350zSJD
Initial_R90 wrote:get a clanging noise at idle its louder then the exhaust when i first start up the car release the clutch about 10-20 seconds later i head a clang from what sounds like the transmission about every 15-30 seconds and it dosent go away you guys have any idea ? its still under warranty untill december if nissan replaces transmission do they put a new one in ?
our cars have a cement mixer running, well the flywheel and it tends to be lound, push the clutch in flywheel no moving, let it out flywheel moving, well i believe that is true, take it in if u want. i have 04 w/ 20k it has been a lil loud,
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I've never heard of a flywheel taht makes noise? i suppose if it's out of balance it could vibrate enough to touch something but if so ti should be fixed, taht kinda of flex in a hit flywheel could casue a spectacular failure
Initial_R90
2003 Evo VIII
well i'm thinking its somthing to do with a clutch trow out bearing i'm hearing dunno tho
Return to “350z / 370z Discussion”
