nw trout »
https://forums.nicoclub.com/nw-trout-u82772.html
Thu Feb 10, 2011 4:43 pm
Just got my 2003 Xterra (3.3L V6 Automatic ) back from dealer recall service (the one to address possible corrosion in the steering column joint). They replaced the column shaft and joint at no cost.
In doing the normal 25 or 30 or 35 point inspection they noted the Timing Belt needed to be replaced. I'm at 106k miles, os its due. I know dealer markup is outrageous but they quoted the job at $1,576 total -(includes water pump, tensioner, other belts). Service guys say this is because most of the front end, radiator, etc needs to be removed to do the work.
A quick call to a local import auto service shop and I got a quote for $638.
What is reasonable?
thanks
-John
aka nw trout
PacNW USA
