03 Sentra SE-R ABS
jhuman
Car: 2003 Nissan Sentra SE-R
Does this model come with ABS standard? I need to change my rear calipers/flush brake fluid and need to know if I need to do anything differently bc I'm not sure if there is ABS or not
audtatious
ABS was standard on the 2.5 Limited Edition, an option for the GXE/SE-R/SE-R Spec V, and not available on the XE
Before doing the brakes just disconnect the battery ground and you don't have to worry about it having ABS or not.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Look under the hood around the passenger side and see if there is a ABS module. It will look like a block with brake lines fed into it.
06_blkout
Car: 2008 Nissan Sentra SE-R Spec V
2006 Nissan Sentra SE-R Spec V (Sold)
2003 Nissan Sentra GXE
Also, you can turn your ignition on and see if an ABS light comes up on the dash for a few seconds to confirm whether or not you have ABS.
