03 QX4. Strong gas odor in very hot conditions
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
Getting towards vacation time, which will be at least partly in the desert. So I should check this out. When it hot out, very hot, and probably working the truck, I get a fairly strong smell of gas. Seems like the middle of the vehicle. I'm looking at the clamps right now on the supply/return but no evidence of leakage as there will often be, but tightening them regardless. Any other thoughts or suggestions? I'm not talking 90F and on the highway, but more like 100+ and 4 wheeling. Nothing ever drips that I can see, but it doesn't take much gas to create a strong odor.
A1Versa
Car: 2009 Nissan Versa SL
soundy like it is running rich check your fuel trim with a scan tool looks like unburnt fuel
heavy hitter
Car: 2001 QX4
Sounds like a problem with the Evap system. Check charcoal cannister, vacuum cut valve, and all vacuum lines to them
Mike W.
2002 BMW 525it
heavy hitter wrote:
Sun Jun 16, 2019 9:24 am
I suppose that's a possibility. My thoughts were more on fuel supply/return, but evap might be more likely. It's not a rich condition, it's coming from underneath not out the tailpipe.
heavy hitter
Car: 2001 QX4
The fact that it only does this when hot leads me towards evap. Also....the strong gas odor as well. I do remember there was a recall for a fuel filler neck issue on certain model r50s. I’m not sure if this applies to your model
