9899pathfinder »
https://forums.nicoclub.com/9899pathfinder-u195839.html
Fri Jun 22, 2018 1:46 pm
Thanks PathyPop. Just finished it without raising the vehicle. Would have had more room to work with the tires off but otherwise went fairly smooth. Besides, getting those large, heavy tires on & off is a project unto itself. Tip for others: install the bottom end of the new shock first because the fixed bolt that affixes it at that end is long. Consequently, if you install the top first, the shock must be pulled outward at the bottom in order to get it to begin lining up with that long fixed bolt. It will start to go on the bolt but it will be cockeyed and it won't slide all the way in.
