03 QX4 Hazard light plug issues
Muggernaut
Car: Infiniti QX4
Can anyone provide me with a picture or diagram showing how these wires are supposed to be positioned In the plug case?
mdmellott
Car: '13 Kia Soul+ 2.0L AT
The hazard switch connector M35 schematic with wire colors and pin out locations can be found on page EL-91 of the factory service manual. https://www.nicoclub.com/service-manual ... 003/EL.pdf Be careful to see that the image of the switch in the schematic may seem to contradict the pin out positions in the M35 connector image. Follow the M35 connector image for the correct pin out locations. The switch image is just for reference and to effectively draw the schematic.
mdmellott
I took a second look at the wire colors you show in the picture compared to the color codes in the schematic and they all look like they match. Nissan and Infiniti sometimes make changes without updating the schematics so I thought I should look again. Pin 5 could be confusing because the color code L stands for Blue. The M35 connector pin number and wire colors are as follows.
1 BR/W (Brown/White)
2 R/Y (Red/Yellow)
3 OR (Orange)
4 G (Green)
5 GY/L (Gray/Blue)
6 GY/R (Gray/Red)
7 P/G (Pink/Green)
8 P/B (Pink/Black)
