loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Nov 09, 2007 9:55 pm
After inspecting the oil pan last night, I took out both front rotors so they can be turned by my mechanic (he owns the shop especializing in Japanese and European cars). I noticed the car has some vibrations during high-speed braking. I also would like to ask his opinion on how to go about with the repair. Unfortunately, he was not there so I just left the rotors to his assistants. I ended up at a Kragen-Milpitas and took a chance with the guy at the counter. I was surprised that he knows about the Q45. He even said that the oil pan in the 03 Q is a structural component of the engine supporting accessories...right on the money. He also said that it will be expensive to have it replaced or repaired by a car shop. The guy is probably a retired mechanic. I was really shocked, no offense meant, but I have been to such shops before - Kragen, AutoZone, PEP Boys and never met any one who knows about Infiniti.
He gave me instructions on how to repair it and just like what Wes mentioned, he recommended J-B Weld, specifically J-B Stik. The performance data on this product looks very good - works on wet and dry surfaces, most metals, including aluminum with temp limit of 250 degrees F (300 peak). I hope it works.
I do most of of the servicing and minor repairs on our cars - 5 Infinitis and 1 Toyota. I do oil change, brakes, brake flush, ATX pan drop and refill, etc.. And now I remember, I was overseas for several weeks in January when the car became due for oil change. So I asked my wife to bring it to a lube shop - $79 for Mobil 1 sythetic. That shop probably over-torqued the drain plug.
Thanks,Rod
