cbird805 »
https://forums.nicoclub.com/cbird805-u198277.html
Wed Jan 08, 2020 3:33 am
It's a 18 year old car. It could be because you tapped the speakers outputs for the subs. Bose systems are a different animal. They have odd speaker impedances (like 1 ohm) and odd amp outputs. Any altering of Bose systems could cause other components to fail, like replacing a speaker with aftermarket one. Try to figure out if the speaker is bad or the amp. One way is check with a known good speaker (like the one on the right side). Or check the amp's output, with a o-scope. Swap out components easiest to change first- speaker/amp/HU. If that doesn't fix it, you need to chek the wires for damage.
