Postby
hotsauce19inSA »
https://forums.nicoclub.com/hotsauce19insa-u303316.htmlMon Jan 17, 2022 10:11 pm
The high beams both right and left are no longer working however the high beam indicator in-dash indicates the high beams are on any advice would be helpful
Postby
Ryantzer »
https://forums.nicoclub.com/ryantzer-u223805.htmlMon Jan 24, 2022 1:35 pm
Test for power and ground at the high beam bulb sockets. If power and ground are good you've got burned out bulbs, if not good then you've got some electrical diagnostic work to do.
Postby
Skibane »
https://forums.nicoclub.com/skibane-u40096.htmlTue Jan 25, 2022 8:05 pm
At least on the Y33 model, the high beam indicator bulb is connected directly across the high beam bulbs - So if it's still working, seems like the problem would be somewhere right around those bulbs.
On the other hand, seems kind of unlikely that both high beam bulbs would go bad at the same time.
You can download a factory service manual (which includes wiring diagrams) for your F50 here.
The high beams have their own fuse, their own relay, and are directly grounded by the combination switch. So a failure in any of those three components can kill both beams. The relevant pages of the WD are LT-14 and LT-15 here: https://www.nicoclub.com/service-manual ... 3%2Flt.pdf
