When installing each rubber part, final tightening must be carried
out under unladen condition with tires on ground.
As long as it represented 'on the ground and unladen', that should be fine. "Unladen" also refers to having a full tank of gas, spare tire in place, and any other stock conditions without passengers or cargo.Upgrayedd wrote:When I replaced mine I had it jacked up with the axle sitting on jack stands. So it was in a lifted state but yet "on the ground". I installed new Moog arms and no problems yet (knock on wood).
