03 Pathfinder SE Radio dash kit
850pathfinder
Car: 03 pathfinder SE
Trying to find the correct dash kit for a single din radio install. The kit i got was listed for the SE but turns out it only fits the LE and is slightly too wide to fit the front dash bezel around it. The metro kit i installed is metro 99-7403. I keep finding double din dash kits but i want the single din with the pocket underneath. Anyone else had this problem and can shed some light?
Blindaviator
Car: 2001 Nissan Pathfinder LE
There shouldn't be a difference between the models for fitment... It wouldn't make much sense to make 3 different dash frames for them... Then again this is Japanese designers...
Blindaviator
Found this one that specifies the SE model... Metra 99-7417
http://www.ebay.com/itm/Fits-Nissan-Pat ... 0012.m1985
850pathfinder
I ordered that one and it doesnt fit either. It seems that the only thing that will fit the 03 SE is a double din unit.
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
As long as you don't have the radio with the slanted RH side, you don't need a dash kit to install a pocket. The metal brackets used on the factory radio just get re-used on the aftermarket radio. You then buy a Nissan OEM single-DIN pocket (68475-35F00) or even a blank mask panel (68470-8B400 or 68470-60M00). I've used both. Both are also held by the re-used factory brackets. All you need then is the antenna adapter and wiring harnesses.
Here is my dash (04 SE w/Bose) with the pocket and single-DIN radio:
...and with modified blank panel:
850pathfinder
thank you so much that was the exact answer i needed
