pathfinder9035 »
https://forums.nicoclub.com/pathfinder9035-u107485.html
Tue Jan 06, 2009 11:12 am
im guesing this is probably your first pathfinder? WEll...u can get an AC lift form 4x4parts.com. Two inch is the only available lift in the market for your R50. If u want to go higher u either have to fabricate your own lift or drop the subframe. but keep in mind. The higher the lift the worst it is on your CV's. So 2 inch lift is what i reccomend and if u want to go hgiher again do a subframe drop so u dont "F" your CV.
you should check out Fuelers pathfinder. I tihnk he has the biggest tires on any stock pathfinder. You should also go into the search box and do a search because their are many forums that adrress this topic. Good luck.
oh yeah i wouldnt trust cheap spacers u can buy out in the market. if i were u i would make fabricate your own spacers that would fit the pathy perfectly.
