03 Path LE seat memory
makingwaves6
Does anyone know how to program the seat memory for an 03 LE Pathfinder?
Thanks!
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
Welcome to NICO!! I haven't done this, but I played with one once. I believe you adjust the seat how you'd like it, then press and hold the number you'd like to assign to that config.
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
That's how my QX4 works -- just hit the "set" and hold down the button.
The seat will only move in "park" so you can't use the memory buttons while driving.
Also, check the dash switch and make sure the memory seats are on. There is a switch (at least on my 2001 Q) just above your left knee when driving, that activates/disables the memory seat function.
