'03 M45 trunk lift supports
jsudaria
Car: 2003 Infiniti M45
Hey Fellers,
I need to replace the trunk lift supports. Has anyone ever done that themselves? Easy or too difficult?
Thanks.
EdBwoy
Pretty easy, just requires some extra steps that might make you scratch your head.
replace-trunk-struts-on-my-2003-m45-y34 ... 69117.html
jsudaria
Thanks again EdBwoy!
EdBwoy
You bet! Good luck with the process.
szh
Car: 2018 Tesla Model 3.
EdBwoy wrote:You bet! Good luck with the process.
Thanks for helping out with the info link! :yesnod
jsudaria wrote:I need to replace the trunk lift supports. Has anyone ever done that themselves? Easy or too difficult?
Yes, the process is pretty straightforward as a DIY ... about 30 minutes or so, as you can see from the information at the link posted above.
Z
mernyfont
Car: 2004 M45 Premium Package B, twilight blue, gray leather [<70,000 miles]
I had a similar question - great answer.
Just to be sure, the links to replacement struts have 9.5 inch when compressed, not 9.0 inches like the post mentions. No big deal?
Thanks.
szh
mernyfont wrote:Just to be sure, the links to replacement struts have 9.5 inch when compressed, not 9.0 inches like the post mentions. No big deal?
Thanks.
Hmmm ... the 9.5" compressed size may be a bit too long and may put a bit too much force on the strut mount when the lid is closed.
I would much prefer 9.0 inches - like the OEM strut dimension - so that even if it does not compress all the way, it will be okay.
Z
szh
Here, for example, is a link to the part: https://www.asraymond.com/standard-gas- ... GSNI515080 that shows a 15" length with a 6" stroke (so compressed length is 9").
Here is another site with the 6" stroke, but they only have a 60 lb strut. This might be a bit low, but may still work ... the price is very good though: https://www.rvupgradestore.com/Articles.asp?ID=298
But I have seen some other sites that seem to support your number ... so not sure now. :confused: I would still try to get a 9" strut if possible.
Do be careful to get the GSNI part (not some others that sound similar) ... that has a nitride finish for corrosion prevention.
The original OEM strut by Stabilus (expensive!) is that compressed length, although at a probable lower pressure of 65 lbs (290 Newtons), I believe.
Z
jsudaria
Well guys I ordered a pair of trunk supports from an ebay seller who had them from a wrecking yard. Just finished the installation and the replacements do not support my trunk just like my old ones. The obvious is that the replacements are bad but maybe someone has an idea of something I"m overlooking??
Geo1140
Car: 2003 M45
Here is a link to where I got mine, I ordered the ones made by Lift Support and they work great.
liftsupportsdepot.com/shopby/2003/infiniti/m45/
jsudaria
Thanks for the link. I just ordered the trunk lift supports.
-Jason
szh
Geo1140 wrote:Here is a link to where I got mine, I ordered the ones made by Lift Support and they work great.
The compressed length of more than 9" was a bit concerning, but if it worked for you, good!
Z
