szhosain wrote:Also, make it a point of asking your dealer if the TSB for transmission reprogramming has been done on your car ... makes a difference!
Z
I just spent some time on my Assist computer... Basicly, there is a reprogram for the TCM (Transmission Control Modual), but it is recommended only to be done if your vehicle is experiencing abnormal shifting problems... If the reprogram is done when not having any problems, it is not certain that it will not cause any problems... (If it aint broke, dont fix)...
To check, you must hook up a consolt and see the program version of the TCM, and IF experiencing the Shift Problem described it is recommended to install the TCM Update...
For giggles, next time I can, Ill hook up the consolt and see what TCM version I am running...
