M45Caliber wrote:1never knew there was a 10mm bolt holding the transmission fluid dip stick down - must be some serious pressure in there!
2QUESTION: What color is the Nissan ATF? This looked almost clear on the dipstick and no color to speak of when wiped on a towel.
3So, now I am at a complete loss. I will continue to drive this until I can replicate the issue for the mechanics OR it just goes away. Any other thoughts appreciated -- thanks again guys.
1The bolt is there because all 03-04 started using Nissan J-Matic that does mix with Dextron or any other transmission fluid. The only fluid that can be safely used is the new Nissan Matic S that is used on the RE7.
2The color of new J-Matic is a light red, it feels very light. It ages to a light brown (~60K under normal conditions) with little to no smell. A visual examination will not give you as much information as a paper towel test. I have a white Post It note stack that I use, the denser paper dissipates the fluid < paper towel keeps any particle matter in a concentrated area. Many times I do a before and after if the owner is interested in seeing it.
3If it is happening infrequently at this point you may have to wait till it's a little more prevalent. Or you could spend hours chasing things, or take it to the dealer once your warranty kicks in to get it looked at.
