szh »
https://forums.nicoclub.com/szh-u149.html
Sat Apr 21, 2007 1:53 pm
Yes, but the selection of tires is a lot lower - nothing really good in that 235/45-18 size.
Many of the other lower aspect ratio tires (below 245/45-18 and 235/45-18) will be troublesome in some way or another.
Remember that the OEM wheel width is 7.5". This restricts the width of tire you can place on the wheel, particularly with lower aspect ratio tires that cannot flex as much to accommodate the smaller height of the tire.
Plus, most of the lower aspect ratio tires, that would be narrow enough to work for the wheel, tend to have lower load index values. Since they are intended for the folks who are increasing up from some lower width tire on a small car.
If you want lower aspect ratio tires, and the gain is not necessarily worth it, imho, then you need to change the wheel to a 19" or 20". Tires that are the correct load index and speed index then tend to be more expensive.
The bottom line: if you want to use the OEM wheel, stick with 235/45 or 245/45 for the right balance between everything.
Z
