Hmmm ... that is not a standard Y34 (2003 M45) key afaik. So, I am a bit confused by what you are describing.whitee01 wrote:It is just a standard key with the RFID chip. No buttons on it at all.
There is something called the "wallet" key though (original owners got this - I have mine somewhere!) - this is something you can carry in your wallet for emergencies to unlock your car.Double E wrote:The valet key.... can you give more info on this? I ask because I'm not aware of a valet version of the key for the Y34. Just the fob and the removable key nested within the fob. Each are the same with no access differences.
That makes a lot of sense, thanks!Double E wrote:SZH, that description of operation is correct. The ability to use the key and do what you described is to allow the car to be moved/towed if the battery is dead (would not allow the chip to be read). A backup to being able to shift to neutral and unlock the steering wheel with a dead battery.
Clearly, as you say, the emergency mechanical key can be used to turn the ignition switch. It does say this in a later section (which I had overlooked before):"The Infiniti Vehicle Immobilizer System will not allow the engine to start or the ignition switch to be turned without the use of the registered Infiniti electronic ignition key."
"The emergency key cannot be used to start the engine, but it can be used to release the steering lock."
Yeah, that is what I was not sure about ...Double E wrote:That second e-bay item is not going to work beyond opening up the doors, trunk & panic.
I looked into this a while back when I wanted a regular spare. I think my research showed that the y34s used a chip #46 like the one you linked... or was it just #6?Dicemoney6 wrote:So one of these keys http://www.amazon.com/Ignition-Transpon ... op?ie=UTF8 should work if it has the cip in it, and I bring it to Infiniti or a good locksmith to get it programmed?
I went to a locksmith today in Decatur, GA and got a metal key like the one I linked to, they used the key that slides in the fob to copy and he programmed it. Cost was $65, he told me any additional key would be $50. So the metal key started the car and I drove home using the copy. It feels funny using a regular key but its way better than paying $500 to $600 which what the dealer told me, then 130 to program the key. I will be getting a remote start over the weekend so I needed this copy.EdBwoy wrote:I looked into this a while back when I wanted a regular spare. I think my research showed that the y34s used a chip #46 like the one you linked... or was it just #6?Dicemoney6 wrote:So one of these keys http://www.amazon.com/Ignition-Transpon ... op?ie=UTF8 should work if it has the cip in it, and I bring it to Infiniti or a good locksmith to get it programmed?
Before putting my M on time out, I was planning to check with a locksmith and ask to compare the chip ID for an 03 M45 vs. any other newish Nissan.
Plan B was to just buy a key like the one you linked and play dumb when I take it to a locksmith to see if it works.
No, the Valet key will NOT work even if you put the FOB up close to the ignition. You will just piss the starter off if you keep turning. I am interested in the key that whitee01 has though.Double E wrote:Just to be clear...there IS an alternative to the new key & locksmith programming path.
If you use the metal slide in key and hold the fob up close to the ignition, it will start. Meaning that if you pull the chip out of the fob and secure it somewhere very close to the ignition switch, or under the dash at the switch, you (in theory) should be able to use the key only. Granted, the key shape is quite convoluted for regular use in the ignition but if you really want to shed the fob and don't care about remote locks, it's an option.
(I personally prefer the route that Dicemoney went and shout props for the success!)
I went to a locksmith today in Decatur, GA and got a metal key like the one I linked to, they used the key that slides in the fob to copy and he programmed it. Cost was $65, he told me any additional key would be $50. So the metal key started the car and I drove home using the copy. It feels funny using a regular key but its way better than paying $500 to $600 which what the dealer told me, then 130 to program the key. I will be getting a remote start over the weekend so I needed this copy.[/quote]I looked into this a while back when I wanted a regular spare. I think my research showed that the y34s used a chip #46 like the one you linked... or was it just #6?
