Hoon is a term used in Australia and New Zealand, to refer to anyone who engages in loutish, anti-social behaviours. In particular, it is used to refer to one who drives a car or boat in a manner which is anti-social by the standards of contemporary society, i.e. too fast, too noisily or too dangerously. In New Zealand, the term "boy racer" is also widely used. Another slang term, revhead—derived from "rev", short for revolutions per minute—is sometimes used in place of hoon. "Anti-hoon laws", while they generally concern road vehicles, sometimes also target anti-social behaviour in motor boats.
Hoon activities can include speeding, burnouts, doughnuts or screeching tyres. Those commonly identified as being involved in "hooning" or street racing are young and predominantly male, although increasingly female, drivers in the age range of 17 and 35 years.
VDC button is nice when off but I still seem some issues with the traction control system playing with the tires. I'll be sure to try that battery pull trick. A straight pipe off the manifold would be pretty sweet, i just need to find myself some flanges.Gene Ln wrote:First, have you turned off the VDC (Vehicle Dynamic control)? this will keep the traction at the expense of acceleration, this among other "Nanny" controls kills the perfectly adequate power of this small V8.
Second try free flow exhaust to free up a little more power. Also I think the Engine management has a learned memory when I first got my car it would not spin the tires very well at all but after exhaust work and lots of relearn, including a battery pull over night for other unrelated issues it seems to have no problem spinning tires every time VDC is turned off
from my limited checking out my car I am fairly sure the 3.69 geared VLSD from the Z will bolt up fine, giving better gearing for burning out, full out acceleration etc. and will have a better semblance of limited slip diff as well. however the car nanny system will apply braking to the excessively spinning rear tire creating a electronic limited slip, albeit at the expense of brake pads though. I would also prefer a real mechanical LSD I like the idea of better gearing, the 3.03 gearing of the stock y34 ideally would help with highway cruising mpg but in town it actually hurts mpg as the engine has to apply more power to get the heavy car moving.EdBwoy wrote:I have read too many vehicle manuals recently, so I might be getting a few things mixed up. If so, please pardon me... but IIRC, with an M45 the VDC system can be basically broken down into the engine management and the traction control part. Even when you push the VDC button, the traction control part is still active, albeit a little more subdued. So, yeah, in the right conditions your handy brake assist nanny will try to keep you in check.
Right conditions above in my imagination is that the car is reading engine speed, wheel speed on all 4 corners and the yaw sensors to know what the car is doing. For example, if you punch your throttle you can burn rubber all day and could probably lay some donuts too, but when you are doing 50 and try to slide around an on-ramp, you'll feel the lady taking control from your crazy a$$.
Talking of which, I can't think of hoonage without envisioning burnouts. Too bad you've got an open diff, and noone that I know has done anything about that on the Y34. Granted, the electronic manipulation from the factory did pretty well for a RWD like this, and even made for easy winter driving, it's just that hoonage requires a different level of dedication. A member here used a LSD from a G35/37 sport on his 06+ M45 and was pretty pleased with the outcome. I don't know how hard it would be to borrow some rear components from the Nissan Z or Infiniti G for yours as well.
Isn't that the truth, I let my buddy take a rip in her during the first snow a few days ago, and he curbed her so hard bent the tie rod into thisEdBwoy wrote:After offering what I have for an answer to your question, here's an alternate suggestion: Get something else if you really want to abuse the car. Not because I love Y34s so much, but parts can be quite expensive for these cars. It's likely that you'll have more $ in it than you can get out of it by the time you're ready to move on after abusing it.
ok here is what I am thinking.EdBwoy wrote:Damn man, that was pretty mangled up! Just so you know, I wasn't trying to jinx you. Are we talking of a bent wheel, front end alignment and possibly torn rubber components?
Granted, that could have happened to any other heavy RWD vehicle in the same conditions, but there are cheaper, lighter and more hoonage-friendly platforms out there.
It seems a good portion of the y34 rear was borrowed from the Z (suspension and driveline). Gene, are you thinking that the electronic braking will still interfere with the VLSD installed? Or are you guys just pointing out a disadvantage of the current (unadvertised) electronic LSD?
The car mpg is already laughable, but hey burnouts don't come cheap.
