03 M45 Coolant leak under intake manifold
ngtr800
Car: 2003 M45
I noticed that the coolant level was low and that the coolant was accumulating underneath the intake manifold just behind the thermostat housing. I used a pump to remove the coolant underneath intake manifold about 24fl oz. I could see the coolant rise just behind thermostat housing when i added more coolant.
Has anyone had a similar experience? and what are some of the suggestions of what it could be? thanks
Car has 94,000 miles and coolant flushed every 20,000 miles.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Just take your car to the dealership and they will be able to fix the problem. :ohno:
ngtr800
Car: 2003 M45
I finally had some free time today to fix the leak under the intake manifold. It turned out to be an o ring that had deteriorated. The o ring from the heater pipe that connects to the cylinder block just behind that water pump. I had to take off the intake manifold, fuel injectors, and a bunch of hoses. It wasn't a hard project i just followed the instructions on the manual that i download from this website.
Don't forget to check underneath the intake manifold for leaks of your m's.
ngtr800
Car: 2003 M45
Here is a picture of the intake manifold removed
Here is another picture of the heater pipe where the o ring went bad
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
surprised more folks haven't had this problem..Or maybe they have?
Going to tackle this myself soon.
