M45Caliber »
https://forums.nicoclub.com/m45caliber-u98401.html
Thu Jan 22, 2009 4:11 pm
OK -- I have a good friend who is an ASE Certified master mechanic and he owns his own independent repair shop in Mesa, AZ. I've used him for years on our "Kid Cars" -- i.e. cars out of warranty and being driven by our kids. He's honest and he's a great mechanic (heck man, he works on Land Rovers and Jaguars when the Scottsdale dealership can't figure out whats wrong... so he's almost a magician - LOL).Anyhow I drove over to his shop and we put it up on the Hunter alignment rack so we could poke around. Diff fluid started coming out before we had the refill (upper plug on the side of the diff) plug out all the way - a nice clear/pale amber color (just a few dribbles so the plug went back in). So we closed that up. Checked all the struts/shocks, checked the driveshaft and various Ujoints - solid. Double-checked all the suspension bolts as he performed the 4-wheel alignment a month earlier ( newest Hunter rack = like watching a laser light show - cool stuff). Checked the wheels and everything seemed bolted down OK. So, Everything underneath solid. Keep in mind that this car was a garaged California car - in MILD semi-arid climate it's whole life, so ALL of the rubber components look new. Amazing - at 38K miles and you could eat off the undercarrage - NO grime or dirt what so ever. Everthing clean and easy to look at, grasp, and "shake" or try and move around.
Dropped the car and fired it up and checked the motor mounts - nadda. That monster motor doesn't move when torqued in gear. Checked the trans fluid level (that was fun -- never knew there was a 10mm bolt holding the transmission fluid dip stick down - must be some serious pressure in there!) Anyhow, the fluid was clear and full - between the two holes on the stick where the word "HOT" is stamped between them - actually touching the top hole but NOT into the hashed marks on the stick above the holes. I did the sniff test and all I smelled was transmission fluid -- nothing even remotely burnt.
QUESTION: What color is the Nissan ATF? This looked almost clear on the dipstick and no color to speak of when wiped on a towel.
So, now I am at a complete loss. I will continue to drive this until I can replicate the issue for the mechanics OR it just goes away. Any other thoughts appreciated -- thanks again guys.
