szh »
https://forums.nicoclub.com/szh-u149.html
Wed Apr 16, 2008 9:40 am
One additional thing I would mention. It is vital to break-in (no pun intended ) the brake pads so that they are properly seated and functioning well from the get go.
The purpose is to avoid ending up with a pad that comes off over time in "clumps" on the rotor when hot because it is still "soft" - this leads to vibration while braking, and confuses people into thinking that their rotors are "warped".
Here is the procedure (modified from the Service Manual).
CAUTION:
Only perform this procedure under safe road and traffic conditions. Use extreme caution, please!
1. Drive the vehicle on a straight smooth road at 50 to 60 mph.
2. Use reasonably hard, consistent braking pressure on the pedal to bring the vehicle down to 5 to 10 mph and heat up the pad and rotors. DO NOT come to a complete stop! There is NO reason to let a hot pad sit on a hot rotor at one physical location and drop a big clump of pad material onto the rotor!
3. Speed up again (don't need to leave tire marks! ) and repeat the above procedure 7 to 10 times - remember, do NOT come to a stop at any time.
4. Go for a cool down drive, on the highway perhaps, for at least 5 to 10 minutes (no braking), never having come to a stop during this entire process.
Z
