03 infiniti i 35 oil burning fast.
LUISARIAS2509
Car: infiniti i 35 2003
My infiniti i 35 03 is burning oil fast. After i Change the oil as soon as it hit 1000 mile after changing it the oil is black and not much is left. Im not sure what's the problem. Help me out thanx.
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
You are DEFINITELY burning oil somewhere. Are you getting any blue smoke or burning smells coming from under the hood? It sounds like it's getting past the rings and burning up in the combustion chamber(s).
LUISARIAS2509
i dont smell any oil or see any blue smoke
MaximA32
'04 Maxima - Traded
'15 Altima
Interesting. You're not getting any drops on the ground anywhere? The oil doesn't just disappear.
LUISARIAS2509
No drop were i park. I just change the oil pan cause I though it was leaking oil but I still have the problem. I'm going to use a 20/50 synthetic oil. Maybe this will help.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
check your radiator to see if oil is there mixed with antifreeze
Check your oil to see if it has water in it
If so you may have a blown head gasket
MaximA32
'04 Maxima - Traded
'15 Altima
NutriaforBreakfast wrote:check your radiator to see if oil is there mixed with antifreeze
That's where I was going next. Hoping it's not the case. If your oil looks like chocolate milk, that's big trouble.
LUISARIAS2509
Ok I'll check it out and will let you know thank for ur help
LUISARIAS2509
No oil found on the radiato or outside the motor. No water mix with antifreeze either.
MaximA32
'04 Maxima - Traded
'15 Altima
LUISARIAS2509 wrote:No oil found on the radiato or outside the motor. No water mix with antifreeze either.
Not water, oil. What color is your oil?
LUISARIAS2509
I just change it a week ago it's caramel color.
NutriaforBreakfast
You need to look IN the radiator not just on the outside of it
When you do, see if there is any oil mixed with water and/or antifreeze
Please do this when the engine is cool or you might get burned and win the Freddy Kruger look alike contest
PLease pull the dipstick on your oil pan inside the engine
Look for water or antifreeze in the oil. As the previous post states, it might look like chocolate milk
LUISARIAS2509
I've check the radiato and the engine no mixuter of oil in the radiato and no antifreeze in the engine. but i did change the oil type just to see if it burn faster. im using 20/50. keep you guys posted.
