qship96 wrote:Old Q door hinges sag without any need for someone "hanging" on the door- lazy or disabled. Just the marginal design Nissan used. Look at a 1970's/1980's Mercedes door hinge if you want to see a quality over-engineered masterpiece of a properly designed lifetime hinge!!!!
I would normally agree with you, but I have opened and closed numerous Q45s with over 120K miles on them (mine only had 72K) and those door hinges were originals and nice and tight. On my car, I know the PO was overweight and lazy based on the trashed interior, the cracked (yes, cracked) drivers seat bottom CUSHION, the broken lumbar motor support and almost dying seat track motors. I was amazed when I pulled off the seat bottom cover to try and resecure it and found the foam cushion split open and literally glued together. I have never seen that and hope I never do again!! I ended up replacing both front seats so they would match.
Sorry, I digress.... Hope the original poster fizes his door hinges. Keep up posted.
