tjrob2000 »
https://forums.nicoclub.com/tjrob2000-u237080.html
Wed Mar 23, 2016 7:31 pm
I have similar symptoms with my '07 G35 Journey with the HR engine, but I'll elaborate a bit more and 916 can chime in if they've had the same.
Wife started car this morning and said it barely started. Tach was below 1000 rpm and fluctuating wildly. Slip, CEL, ABS, pretty much all lights were on.
Later I start the car and it starts normally. Take it for a drive (was going to Autozone to see if there are any pending codes) and after pulling into heavy traffic it starts bucking, slip, VDC, CEL, ABS, Brake lights are all on. Speedo drops to 0 at one point even though we are going 20mph. Initially after startup it would rev normally. At this point, after the stumbling occurred, it would barely make 3000 rpm. Searching I've done appears to lead to the Crank sensor or one/both cam sensors. I'm going to get it to a service shop tomorrow morning (hopefully), but thought I'd post here to see if anyone has other ideas.
