Postby
pae9132 »
https://forums.nicoclub.com/pae9132-u55321.htmlSat Jun 16, 2007 11:41 pm
I haven't been able to get an answer from anyone in the mechanic zone so I'm trying here. I can't find the stock size in "mm" for the front and rear sway bars on a 2003 g35 sedan. I thought you could find anything on the net. Thanks for the help.
Postby
pae9132 »
https://forums.nicoclub.com/pae9132-u55321.htmlMon Jun 18, 2007 5:44 am
I was thinking about an aftermarket sway bar but the car is already built well so I thought just adding some urethane bushings might be all I would need but I can't find any. Someone I talked to mentioned that they might already be urethane but I can't find it anywhere. I guess I'll just save for the sway bar set.
