03 g35 2-3 shift
Newtothegworld
Car: 03 Infiniti G35
Ok I've got a p1769 h/l/r solenoid code. The solenoid ohms out fine, no problems between solenoid and TCU. It just won't shift into high gear. I'm thinking either pressure switch 6 is bad or the temp sensor but I only ever get 1 code. Sometimes it will shift correctly but for the most part all I can do is about 80 wide open is there any way to check the pressure switch ? Or the temp sensor ? Idk I'm lost and I'm normally pretty good at transmissions
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's very unlikely that's an electrical problem, you'd be getting P1767 instead of P1769 if the solenoid coil failed or P1846 if PSC2 (switch 6) was inoperative. P1769 isn't a hard code, it's a performance code that means the TCM is trying to shift but the valving or clutch isn't responding. Most likely you have a sticky/leaky shuttle in the Valve Body or the HLRC clutch is just worn out.
Newtothegworld
That what I thought too but the h/l/r valve moves freely. I can manually engage the h/l/r solenoid while she's running down the road an shifts perfectly with no slippage. The temp sensors reading correctly. Only thing left is a pressure switch (that can't be changed out because it's the early style valve body) it threw me for a loop because it didn't show a ps code I'm gonna do something stupid and throw a toggle in line of the switch wiring to confirm though
VStar650CL
Technical Expert
Any old port in a storm. That's weird behavior though, if it shifts manually. You should be getting a P1846 if the TCM tries to shift by itself and it doesn't transition. I'll be interested to see if the switch does the trick.
Newtothegworld
I ran a toggle switch to act like pressure switch number 6 and you can leave it in drive and it shifts through all the gears right so I can confirm the pressure suit was bad but I'll have to get ahold another valve body
VStar650CL
Technical Expert
:dblthumb:
Hopefully you can get one, a lot of those older Infiniti VB's are getting hard to find. I'll cross my fingers for you.
